Enables a peer group and all the neighbors of a peer group.
| peer-group-name | Specifies a peer group. |
Disabled.
source-interface
out-nlri-filter
out-aspath-filter
out-route-map
send-community
next-hop-self
This command applies to the current VR or VRF context.
The following command enables the BGP peer group outer and all its neighbors:
enable bgp peer-group outer
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
